new addition to the family!
Re: new addition to the family!
by big_gordy » Sat Nov 20, 2010 9:59 pm
what 2 pins should i bridge to get the fault codes? any help would be good!
:obscene-drinkingbeer:
by Fraz » Sat Nov 20, 2010 11:09 pm
or read the answer you got to the question
viewtopic.php?f=13&t=45544&start=30
by Callyman » Sat Nov 20, 2010 11:19 pm
Thanks for posting that Fraz, I thought we covered that before.
by v6 steve » Sat Nov 20, 2010 11:46 pm
the body work of the car is earth or you could dig a hole in the ground and stick it in there as its earth too
by Callyman » Sat Nov 20, 2010 11:47 pm
Gordy, the entire metal body work of the car is earth.
Up to you what part you choose.
by Fraz » Sat Nov 20, 2010 11:47 pm
in simple terms it means you find a good earth point, you then get a bit of wire and take it from pin 6 to the earth point
it never said bridge pin 6 to the earth pin of the connector
by big_gordy » Sun Nov 21, 2010 3:34 pm
this is what i am getting !
is this the fault for egr?? :think:
by v6 steve » Sun Nov 21, 2010 3:35 pm
yee thats clear as mud think you must have put the wire in the ground all right
by Fraz » Sun Nov 21, 2010 4:05 pm
it is
1/4/10/5
so code is 1405, exhaust gas recirculation (EGR) valve position sensor malfunction
and I know you have autodata, and that is the same place I got that info from
by Fraz » Sun Nov 21, 2010 4:11 pm
autodate also shows you how to check the EGR valve, but It could just be a hose off or one with a leak
by big_gordy » Sun Nov 21, 2010 8:24 pm
thanks for the confirmation guys
