new addition to the family!
Re: new addition to the family!
what 2 pins should i bridge to get the fault codes? any help would be good!
Thanks for posting that Fraz, I thought we covered that before.
the body work of the car is earth or you could dig a hole in the ground and stick it in there as its earth too
Gordy, the entire metal body work of the car is earth.
Up to you what part you choose.
in simple terms it means you find a good earth point, you then get a bit of wire and take it from pin 6 to the earth point
it never said bridge pin 6 to the earth pin of the connector
yee thats clear as mud think you must have put the wire in the ground all right
it is
1/4/10/5
so code is 1405, exhaust gas recirculation (EGR) valve position sensor malfunction
and I know you have autodata, and that is the same place I got that info from
1/4/10/5
autodate also shows you how to check the EGR valve, but It could just be a hose off or one with a leak
thanks for the confirmation guys
