Windows stuck!
Windows stuck!
For some strange reason my drivers side windows has stopped moving..
It was playing up at the start of the week, I could sit stationary for 20 mins and sometimes it would go up and sometimes it wouldn't. When it did move it sounded fine.Now it won't budge at all.
Where should I start to try and find the problem?
I've checked the fuse.......
noelboy
My driver's side window did that when I first got the car, and it turned out to be the motor. to the tune of about 250 euros!
The other day, when the temperature hit over 30, my passenger window started acting up! I hope I don't have to change that one now.
I wonder if the motor for both sides is the same? Because only my drivers window has the one-touch feature. I wonder if it's possible to use a driver's side motor on the other one to function the same way....
King Calibra
noelboy
The majority of the time it is the motor that is at fault. You should be able to get a decent replacement from a scrappers for around £20-30. You neede to drill the rivets out and rivet the new one in, the electrical plug on the back of the motor has a metal clip that needs to come off as well.
Monkey
<!--quoteo--><div class='quotetop'></div><div class='quotemain'><!--quotec-->The majority of the time it is the motor that is at fault. You should be able to get a decent replacement from a scrappers for around £20-30.<!--QuoteEnd--></div><!--QuoteEEnd-->
Does it have to be from a calibra? 'Cos not much chance finding one of those where im from.
damon
