cannot remove rear spring!
Cannot get the spring to come out, got a tool to compress it but it is not enough, how do you get it out?
Also this is my new spring, which is the top, A or B?
Thanks
car is in bits, pls help, need to sort it b4 tonight
tara
Thanks
tara
Molecule
You just need to jack the car up and take the spring out. You shouldn't need to use the compressers.
Can't remember from when I did mine but I think "A" goes to the top.
bought the kit from europerformance, they sent 4 yellow koni shocks and these red swedish springs, on the box they are marked as "LESJOFORS" ( <a href="http://www.lesjoforsab.com/default.asp" target="_blank">http://www.lesjoforsab.com/default.asp</a> )
Have not measured the coils b4 slapping them on but they look bigger
Molecule
