cannot remove rear spring!
by Molecule » Tue Feb 14, 2006 1:49 pm
Cannot get the spring to come out, got a tool to compress it but it is not enough, how do you get it out?
Also this is my new spring, which is the top, A or B?
Thanks
car is in bits, pls help, need to sort it b4 tonight
tara
Molecule
by Mark1 » Tue Feb 14, 2006 1:55 pm
You just need to jack the car up and take the spring out. You shouldn't need to use the compressers.
by Molecule » Tue Feb 14, 2006 2:04 pm
ah I think I need to unscrew something else, should come come out after that.
what about the new spring?
A or B?
Molecule
by Mark1 » Tue Feb 14, 2006 2:13 pm
Can't remember from when I did mine but I think "A" goes to the top.
by Fraz » Tue Feb 14, 2006 2:16 pm
you put it on with the wording on spring facing the correct way
by Molecule » Tue Feb 14, 2006 2:24 pm
got the spring out.
Will put A top
Where do these powerflex bump stop go?
Within the spring at the bottom?
Molecule
by Molecule » Tue Feb 14, 2006 4:10 pm
well I just finished, 3 hours but, not lowered at all.......( should be -35 ). is it a matter of waiting until they settle in?
Molecule
by Stupink » Tue Feb 14, 2006 4:53 pm
erm.. no.. they're possibly the wrong springs, or more likely the car was already lowered.
by Molecule » Tue Feb 14, 2006 5:41 pm
thing is the last coil internal diameter is much bigges than the rubber seating on the arm, I mean the spring could be pulled or pushed left to right
Molecule
by Molecule » Tue Feb 14, 2006 6:47 pm
Thanks Stu,
think u r right, they must have sent the wrong F******* springs, called them up and tomorrow will have a chat with a technician......Need my car tonight, well pi**** off
Molecule
by Stupink » Tue Feb 14, 2006 6:49 pm
Do a photo of the rear as its sitting.. its easy enough for us to see if its std or -35
by Molecule » Tue Feb 14, 2006 7:10 pm
This is my original spring. the diameter indicated is 40mm, the new is a lot bigger and would move around the seating on the lower arm. The new is the red one posted at the beginning, the last three coils touch each other when the car is off the jack.
thanks mate
Molecule
by Fraz » Tue Feb 14, 2006 8:53 pm
what make are these springs?
and another factor is the width of the spring coils
by Molecule » Tue Feb 14, 2006 9:06 pm
bought the kit from europerformance, they sent 4 yellow koni shocks and these red swedish springs, on the box they are marked as "LESJOFORS" ( <a href="http://www.lesjoforsab.com/default.asp" target="_blank">http://www.lesjoforsab.com/default.asp</a> )
Have not measured the coils b4 slapping them on but they look bigger
Molecule
by Fraz » Tue Feb 14, 2006 9:08 pm
is there any part numbers or markings on the springs...have heard of them before , not to bad a spring IIRC
