Mystery lead/sensor
by Fraz » Wed Apr 12, 2006 12:45 am
just the location of where the end plugs in ..was just a thought (do they work your washers?) as for the end could it not be someone has cut pulled the end off and used some sort of heat shrink on the ends?
by dan1w » Wed Apr 12, 2006 12:59 am
<!--QuoteBegin-Fraz+--><div class='quotetop'>(Fraz)</div><div class='quotemain'><!--QuoteEBegin-->as for the end could it not be someone has cut pulled the end off and used some sort of heat shrink on the ends?<!--QuoteEnd--></div><!--QuoteEEnd-->
No, 'cos there's a white bit of plastic in the end as well. Unless it was some unused bit of loom that was blanked off in the factory.
dan1w
by dan1w » Wed Apr 12, 2006 6:33 pm
*bump*
dan1w
by RobbieV » Wed Apr 12, 2006 6:37 pm
<!--QuoteBegin-dan1w+--><div class='quotetop'>(dan1w)</div><div class='quotemain'><!--QuoteEBegin-->*bump*<!--QuoteEnd--></div><!--QuoteEEnd-->
No bumps please.
by mickeyboy » Wed Apr 12, 2006 7:16 pm
i think your find its probly just something that vauxhall plug into when they do a turn up or something like that
mickeyboy
by Johnnytenpints » Wed Apr 12, 2006 9:18 pm
tbh to me it looks like a brake pad wear plug. Shouldn't be up there in the engine bay though. Have a pic of mine at home but not there till monday so that don't help much sorry. Do you have a check light on your dash?
Johnnytenpints
by dan1w » Wed Apr 12, 2006 9:44 pm
Cheers Johnny but it's not the wear sensor. I have those tied off by the discs. I'm still thinking temp sensor, gonna go check if it's down by the bumper.
dan1w
by nickG » Fri Apr 14, 2006 11:44 am
If the wires on the plug are blue and white then it's the temp sender.
nickG
by dan1w » Sat Apr 15, 2006 10:58 am
Nah, they're green and brown. Still haven't got around to checking this. Yet more problems elsewhere!
dan1w
by Animal » Sat Apr 15, 2006 11:07 am
I've never seen that conector that you have in the engine bay before.
Strange.
by MR_TOAD » Sun Apr 16, 2006 12:02 pm
its the thingymebob in the googly pin
thats what it is
MR_TOAD
Users browsing this forum: Bing [Bot] and 11 guests
