OMP front strut brace to a Calibra Turbo
Has anyone fitted a OMP front strut brace to a Calibra Turbo? I'm looking at it and it looks like were you are ment to drill the bolt holes will drill straight into the suspension strut top mount which i would have thought would be bad, any ideas?
chunkylover
<!--QuoteBegin-chunkylover+--><div class='quotetop'>(chunkylover)</div><div class='quotemain'><!--QuoteEBegin-->Has anyone fitted a OMP front strut brace to a Calibra Turbo? I'm looking at it and it looks like were you are ment to drill the bolt holes will drill straight into the suspension strut top mount which i would have thought would be bad, any ideas?<!--QuoteEnd--></div><!--QuoteEEnd-->
Yeah think you will find that a strut brace purpose is there to hold the suspension struts and stop em from twisting.
dicky
Ideal solution would be to do like Rob off migweb (sbd16v) has done on his astra and weld on re-enforced strut tops with the mounts built into them, but drilling and bolting is acceptable.
The purpose of it is to simply keep the strut tops a fixed distance from each other at all times, many strut braces on the market dont work though, avoid anything with a major radius in it, it just wont be rigid enough.
chip
