OMP front strut brace to a Calibra Turbo
by chunkylover » Sun Oct 29, 2006 2:07 pm
Has anyone fitted a OMP front strut brace to a Calibra Turbo? I'm looking at it and it looks like were you are ment to drill the bolt holes will drill straight into the suspension strut top mount which i would have thought would be bad, any ideas?
chunkylover
by splinter » Sun Oct 29, 2006 2:33 pm
I think your find thats where they go ... Mine does..
by Fostersice17 » Sun Oct 29, 2006 3:30 pm
Yup,mines a spraco one,and fits in the same place.
Fostersice17
by dicky » Sun Oct 29, 2006 3:36 pm
<!--QuoteBegin-chunkylover+--><div class='quotetop'>(chunkylover)</div><div class='quotemain'><!--QuoteEBegin-->Has anyone fitted a OMP front strut brace to a Calibra Turbo? I'm looking at it and it looks like were you are ment to drill the bolt holes will drill straight into the suspension strut top mount which i would have thought would be bad, any ideas?<!--QuoteEnd--></div><!--QuoteEEnd-->
Yeah think you will find that a strut brace purpose is there to hold the suspension struts and stop em from twisting.
dicky
by MJ » Sun Oct 29, 2006 3:41 pm
I think everyones missing his point ......
yes you drop the suspension down out of the turret first so you can attach the nut and bolt, dont drill straight into the strut!
MJ
by chip » Sun Oct 29, 2006 3:44 pm
Ideal solution would be to do like Rob off migweb (sbd16v) has done on his astra and weld on re-enforced strut tops with the mounts built into them, but drilling and bolting is acceptable.
The purpose of it is to simply keep the strut tops a fixed distance from each other at all times, many strut braces on the market dont work though, avoid anything with a major radius in it, it just wont be rigid enough.
chip
by chunkylover » Sun Oct 29, 2006 3:48 pm
Has anyone got any picks? so i can get it clear in my head. My brace does not have the round mounts. Mines just has a plate with 4 screw holes which mount on the side of the turret. It just doesn't look right.
chunkylover
by mwcav » Sun Oct 29, 2006 8:46 pm
Sorry to hijack, I was gonna ask the same question, but I have a strut brace which bolts in two places, but no holes around the turrets, as I understand from what has been said above, do I drill through the strut and bolt it, or remove the strut and drill?
mwcav
by Fostersice17 » Sun Oct 29, 2006 11:31 pm
Well here is mine,you can see their is a bolt on the top,but you can't see their is also one around the other side,on a metal tab that is lower than the rest of the ring.
Fostersice17
by chunkylover » Sun Oct 29, 2006 11:34 pm
Yeah mines not like, I'm wondering if its the wrong one for my car even tho it does say calibra on it?
chunkylover
by Fostersice17 » Sun Oct 29, 2006 11:36 pm
It is possible,most of them are the same shape,just different fittings ect
Fostersice17
by Animal » Mon Oct 30, 2006 12:53 am
There is one that bolts on the front of the turrets. With a square mounting plate.
by Animal » Mon Oct 30, 2006 12:58 am
ImageLike that.
by mwcav » Mon Oct 30, 2006 9:04 am
The one I have to fit is like that but with "c" shapes that go round the turret, mines an XE by the way, can I just drill and bolt or do I need to remove the leg underneath?
mwcav
by Chavtastic » Mon Oct 30, 2006 10:11 am
You don't need to remove the leg. When it comes to cramming the nut on the back of the bolts, just raise the car up and down slowly on a jack until you can get your fingers in with the nut. You will be able to get round the strut, just!
