Discs and pads on a V6
by Nick » Fri Jan 19, 2007 9:17 pm
Are there any recommendations for the best make of discs and pads on a V6 Calibra and whether drilled or grooved or both are the best?
Nick
by casper » Fri Jan 19, 2007 9:28 pm
<!--QuoteBegin-Nick+--><div class='quotetop'>(Nick)</div><div class='quotemain'><!--QuoteEBegin-->Are there any recommendations for the best make of discs and pads on a V6 Calibra and whether drilled or grooved or both are the best?<!--QuoteEnd--></div><!--QuoteEEnd-->
i had grooved blsckdiamond discs on my last cav v6.paid 105 squid from ad in t.v.unfortunately cant member wot ad.they started 2 squeal slightly after approx 18month but that coulda been a bit of gravel on a pad or glazing i suppose.anyway their a lot cheaper than o.e. parts and look good.it was a small firm way down south
casper
by casper » Fri Jan 19, 2007 9:29 pm
i had vaux pads if i member right
casper
by Mark1 » Fri Jan 19, 2007 11:06 pm
I have Tarox 308mm grooved disc, GSI calipers and Blackdiamond pads on the front and Blackdiamond grooved disc and pads on the back and it works well.
Club Treasurer
Club Treasurer
by Nick » Fri Jan 19, 2007 11:48 pm
Are the Vectra Gsi calipers and if so does the brackets need altered?
Nick
by Mark1 » Fri Jan 19, 2007 11:57 pm
I didn't get any brackets in the kit.
<a href="http://www.lmfvauxhall.com/prodCatalog/default.aspx?prodId=896&deptId=192&catId=&catIndex=&deptIndex=1" target="_blank">http://www.lmfvauxhall.com/prodCatalog/def...ex=&deptIndex=1</a>
Club Treasurer
Club Treasurer
by Nick » Sat Jan 20, 2007 12:33 am
Yeh that kits only available if you have 288mm disc and mine are 284's unfortunately.
Nick
by Mark1 » Sat Jan 20, 2007 12:40 am
Give them a call and see what they can do for you, if you'er a memeber you will get a discount as well.
They are very helpful.
Club Treasurer
Club Treasurer
by Nick » Sat Jan 20, 2007 12:54 am
Cheers for that.
Nick
