Discs and pads on a V6
Are there any recommendations for the best make of discs and pads on a V6 Calibra and whether drilled or grooved or both are the best?
Nick
<!--QuoteBegin-Nick+--><div class='quotetop'>(Nick)</div><div class='quotemain'><!--QuoteEBegin-->Are there any recommendations for the best make of discs and pads on a V6 Calibra and whether drilled or grooved or both are the best?<!--QuoteEnd--></div><!--QuoteEEnd-->
i had grooved blsckdiamond discs on my last cav v6.paid 105 squid from ad in t.v.unfortunately cant member wot ad.they started 2 squeal slightly after approx 18month but that coulda been a bit of gravel on a pad or glazing i suppose.anyway their a lot cheaper than o.e. parts and look good.it was a small firm way down south
casper
i had vaux pads if i member right
casper
I have Tarox 308mm grooved disc, GSI calipers and Blackdiamond pads on the front and Blackdiamond grooved disc and pads on the back and it works well.
I didn't get any brackets in the kit.
<a href="http://www.lmfvauxhall.com/prodCatalog/default.aspx?prodId=896&deptId=192&catId=&catIndex=&deptIndex=1" target="_blank">http://www.lmfvauxhall.com/prodCatalog/def...ex=&deptIndex=1</a>
Give them a call and see what they can do for you, if you'er a memeber you will get a discount as well.
They are very helpful.
