Quick V6 Brake disk size question
quicky before i order some brake disks and pads for the cally
just need to know the size of the v6 rear brake disks as i want to order some from mtec on ebay
Fronts are 288mm x 25mm
Rears are 270mm x 10mm
i got this info from v6calibra.net
V6 Braking System
FRONT: 288mm vented discs (early V6's used 284mm)
REAR: 270mm solid discs with integral hand brake (shoe type )
as mine is the later of the models i assume they are the 270x10 or would i be better off just measuring them to make sure or did all V6's have 270x10 rear disks
V6 Braking System
Cozy
One thing to make sure is you have the distance from the mounting face for the wheel and the brake disc surface on the rears as there are two different depths of disc with on being much shallower than the other as the later ones had the brakes discs from the first type of vectra gsi
P Reg V6 In Titanium Pearl thats going to be stripped for parts now after being let down on it being bought whole
Now in a Crono yellow 2010 Seat Leon Cupra R with all the toys
All,
The very late SE9s had the same discs, pads and shoes fitted as early Vectra(Saab). I don't think this is well known as neither Halfords nor 2 other local motor factors had this listed!
Strangely the later SE9s had smaller rear discs than the earlier cars if I recall correctly.
I still have the box downstairs so can check the precise Vectra / Saab year required if this would help.
Regards Vanguard
Regards Vanguard
Vanguard
