Quick V6 Brake disk size question
by Cozy » Wed Feb 20, 2008 2:52 pm
quicky before i order some brake disks and pads for the cally
just need to know the size of the v6 rear brake disks as i want to order some from mtec on ebay
Fronts are 288mm x 25mm
Rears are 270mm x 10mm
i got this info from v6calibra.net
V6 Braking System
FRONT: 288mm vented discs (early V6's used 284mm)
REAR: 270mm solid discs with integral hand brake (shoe type )
as mine is the later of the models i assume they are the 270x10 or would i be better off just measuring them to make sure or did all V6's have 270x10 rear disks
Cozy
by RobbieV » Wed Feb 20, 2008 4:14 pm
Your info is correct for the later V6's
Front 288mm x 25mm
Rear 270mm x 10mm
by Mantaray » Tue Mar 25, 2008 12:43 pm
I ordered a set of EBC Turbo groove rears from LMF. According to them, the later V6's have 284mm rear discs, so I ordered them! It appears there info is wrong! I can only assume these are later Turbo only, even tho I thought the brakes were the same on both models......
Mantaray
by Mantaray » Tue Mar 25, 2008 1:04 pm
96 P reg
Mantaray
by trev150 » Wed Mar 26, 2008 10:27 pm
Are they not interchangable?
by Mantaray » Thu Mar 27, 2008 3:39 pm
Not exactly. the bigger discs will foul the calipers.
Mantaray
by V6_E » Thu Mar 27, 2008 4:50 pm
One thing to make sure is you have the distance from the mounting face for the wheel and the brake disc surface on the rears as there are two different depths of disc with on being much shallower than the other as the later ones had the brakes discs from the first type of vectra gsi
P Reg V6 In Titanium Pearl thats going to be stripped for parts now after being let down on it being bought whole :(
Now in a Crono yellow 2010 Seat Leon Cupra R with all the toys
by Mantaray » Mon Mar 31, 2008 3:42 pm
Apart from the diameter they appear identical.
Mantaray
by Vanguard » Sat Apr 05, 2008 11:30 pm
All,
The very late SE9s had the same discs, pads and shoes fitted as early Vectra(Saab). I don't think this is well known as neither Halfords nor 2 other local motor factors had this listed!
Strangely the later SE9s had smaller rear discs than the earlier cars if I recall correctly.
I still have the box downstairs so can check the precise Vectra / Saab year required if this would help.
Regards Vanguard
Vanguard
