Abs Light on and its not working
by PuppiesBalls » Thu May 15, 2008 5:59 pm
Ive put on my new Brakes and the abs light is on and the abs isnt working,
ive bled off the brakes, but the light wont go out,
i took it for a little spin up the road today and it locks the front quite easily(was quite damp)
any idea what could be up with it?
Cheers Guys
Ross
PuppiesBalls
by cornishtaz » Thu May 15, 2008 6:03 pm
Possibly you've dislodged a sensor or sensor cable. You can do the paperclip test by shorting out the following pins A+K on the diagnostic plug. Then turn on ignition and the ABS light will flash the code out starting with 1 flash then 2 flashes this is repeated 3 times then the fault code will be flashed out. Post results and we'll let you know the problem
cornishtaz
by PuppiesBalls » Thu May 15, 2008 6:05 pm
back in a jiffy :-k
PuppiesBalls
by PuppiesBalls » Thu May 15, 2008 6:08 pm
#37
PuppiesBalls
by cornishtaz » Thu May 15, 2008 6:11 pm
Looking at the faults codes it seems that 37 is the stop lamp switch(pedal switch).
cornishtaz
by PuppiesBalls » Thu May 15, 2008 6:25 pm
my bad, i put pin a to k not a-b lol
done a-b now and its just comin up with the diagnostic start up
PuppiesBalls
by cornishtaz » Thu May 15, 2008 6:27 pm
ABS is deffo A+K not A+B
cornishtaz
by PuppiesBalls » Thu May 15, 2008 6:31 pm
just checked again mate its deffo 37
PuppiesBalls
by cornishtaz » Thu May 15, 2008 6:41 pm
Are your brake lights working ok? Will look at Haynes cct diag
cornishtaz
by PuppiesBalls » Thu May 15, 2008 7:13 pm
no rear lights in at the moment, would that stop the abs working?
PuppiesBalls
by cornishtaz » Thu May 15, 2008 7:35 pm
Wouldn't have thought so, its just a good way of testing the switch with out getting under the driver footwell
cornishtaz
by RobbieV » Thu May 15, 2008 7:44 pm
PuppiesBalls wrote:no rear lights in at the moment, would that stop the abs working?
Do you mean the whole lights or just the brake lights are not working ?
by PuppiesBalls » Thu May 15, 2008 10:18 pm
No lights at all mate, im just re spraying the car at the moment, so the lights are out, and yer they are after burners.
Its a problem with the ABS, it defiantly ain't working there locking up!
PuppiesBalls
by cornishtaz » Thu May 15, 2008 10:22 pm
When light is on ABS is disabled. Might be worth waiting till you've got car back together before continuing any fault finding
cornishtaz
by PuppiesBalls » Fri May 16, 2008 12:56 am
okay cheers guys will let you know how it turns out
PuppiesBalls
