Abs Light on and its not working
Ive put on my new Brakes and the abs light is on and the abs isnt working,
ive bled off the brakes, but the light wont go out,
i took it for a little spin up the road today and it locks the front quite easily(was quite damp)
any idea what could be up with it?
Cheers Guys
Ross
Cheers Guys
Ross
PuppiesBalls
Possibly you've dislodged a sensor or sensor cable. You can do the paperclip test by shorting out the following pins A+K on the diagnostic plug. Then turn on ignition and the ABS light will flash the code out starting with 1 flash then 2 flashes this is repeated 3 times then the fault code will be flashed out. Post results and we'll let you know the problem
cornishtaz
Users browsing this forum: Bing [Bot] and 11 guests
